8 volt battery - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-02-2010, 07:49 PM
8 volt battery
I just want to buy an 8 volt battery. No other interests at this time.
Old 12-02-2010, 07:54 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Welcome to the site, You need to check our classified section there you can look around and place a wanted ad while you are there it's free. No advertising for sale or wanted on the board is not allowed.
Cole
Old 12-03-2010, 05:09 AM
poncho62's Avatar
Wiki Edits: 5
Never heard of an 8 volt battery.....
Old 12-03-2010, 05:27 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
as I recall 8 volt was used for a few years. Farmers used them in 6 volt equipment often from what I have read over the years
Old 12-03-2010, 05:51 AM
Wiki Edits: 27
8 volts
On an old style coils and points regulator you can use a volt meter to check as you bend the spring brackets to get the generator output high enough to charge your 8 V battery . The 8 volt ones are hard to find, Usually easier on old equipment to install a 12 V one wire alternator, leave the 6 v starter in place, just don't crank too long. change the light bulbs and ignition coil or add a resistor.
Old 12-03-2010, 05:57 AM
Check with a farm supply store. 8 volt batteries were sometimes used on farm tractors. The previous owner had even installed one in my 1948 Plymouth, but I've since converted to 12 volt.
Old 12-03-2010, 06:06 AM
poncho62's Avatar
Wiki Edits: 5
Moving this to electrical forum
Old 12-03-2010, 02:29 PM
Joe G's Avatar
x2
I used to be a parts guy at a Ford/New Holland dealership. We stocked 8v batteries for the people who had hard starting 6v tractors. Instead of cleaning all the wiring connections on their old tractor, they would just throw an 8v battery in it. It might have been a little harder the on the points and coil, but on an 8n/2n/9n, those parts were super cheap.
One word of caution, if you have an original tube style radio, or an autronic eye automatic headlight dimmer, the extra voltage can fry some of the tubes.
Good luck...
Old 12-03-2010, 05:28 PM
eloc431962's Avatar
Wiki Edits: 37
Didn't some golf carts have a 8 volt battery also ?
Cole
8 Volt battery Frank D Electrical 6 06-18-2010 10:27 PM
12 volt 3 amp battery charging fast68 Garage - Tools 3 02-25-2010 11:08 AM
Roll Bar Install Advice Mustangsaly General Rodding Tech 12 12-02-2007 08:33 AM
Need help please with an electrical headake bowtieorbust Electrical 15 01-26-2006 03:01 PM
6 volt-12 volt battery question MeEatsPigBrains Electrical 5 11-14-2005 01:49 AM
