80/90 gear lube ok for sm-465 and non possi rear end? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-01-2003, 06:34 PM
Post 80/90 gear lube ok for sm-465 and non possi rear end?
I have a 53 Chevy 5 Window pickup that I just got done putting a Muncie SM-465 4 speed and a 12 Bolt open end out of a 73 donner truck is it OK to just run 80/90 gear lube in this manual tranny and rear end?
Old 03-01-2003, 06:58 PM
New Member
Post
i have a 74 chevy 4x4 with an sm465 and rear 12 bolt. i run 80/90 for tranny, transfer case and both axles. living in az the temp stays pretty mild so if it gets pretty cold where you are you might consider 75/90 or something like that so its not too thick on those 10 below 0 mornings.
Old 03-02-2003, 05:06 AM
dklong's Avatar
Post
use what the manufacture specifies in the rear ends and trans and transfer case.
