'80 Camaro rear tires width - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-13-2005, 06:49 AM
How big rear tires can I put under my stock '80 Camaro? I have 295/60R15 at garage, but I can't try them at the moment. I can return these tires if they don't fit, so I would like to know...
Thanks!
Old 09-13-2005, 05:36 PM
Canzus's Avatar
a red wool sock on his dinger
I'll put the imfamous "It depends" on this one, the largest
I'd run on my former '78 Z28 was a 255/60-15, and I don't
think an extra 40mm would fit... YMMV...
Old 09-13-2005, 10:06 PM
1969NovaSS's Avatar
turbo lag......yeeeeehaaaaaaw
tire size
A 295/60r15 is a 30 inch tire. I dont think that will fit under there. are you sure its not a 295/50 r15 that might fit as its a 26 inch but its also got a sectional width of 12.3 i believe. I have some under my nova and its lowered over the tires. I would take them to a shop and just tell them to test fit it. Some places would probably do it for free.
Old 09-14-2005, 12:30 AM
rear tires
i have 275/50 on mine on stock z-28 aluminum wheels i would not go any bigger than that because it almost rubs
82-92 camaro posi rear end info NoEgoMan100 Transmission - Rearend 4 10-21-2005 02:22 PM
rear end swap 91 camaro rs twisted91 Transmission - Rearend 5 01-10-2005 06:25 PM
will a 4th gen camaro rear end fit 3rd gen? 84Z Transmission - Rearend 2 05-13-2004 07:51 PM
79-93 Mustang 8.8" Rear Differential Width From Hub-To-Hub nightrain_rod Transmission - Rearend 1 12-04-2003 07:59 AM
R.E. width with wheels & tires jcarter Transmission - Rearend 1 09-27-2003 01:30 PM
