-   -   80' chevy c10 parking brake problem (http://www.hotrodders.com/forum/80-chevy-c10-parking-brake-problem-174133.html)
80chevybigten 03-08-2010 08:30 AM
I have an 1980 chevy big ten model half ton with a little bit of an issue. I need it to pass a safety inspection. For that my parking brake needs to work. I know what the problem is but not quite sure on how to fix it. on the firewall just above the brights switch and underneath the dash there is a cable that fits into a bracket that sets the parking brake. Right next to the breaker. Right now the cable is not in its bracket. I tried to pull it up with pliers and I got it up a bit more. I got underneath the truck and found the cable and tried to shove it up into the cab and that helped a bit moe as well. I removed the rubber piece on the parking brake pedal so I could raise it higher so the bracket would come closer to the cable and that helped a little. But I need another 1/8 of an inch or so and I cant get it there. Any ideas on what I can do to fix this problem?
joe_padavano 03-08-2010 08:41 AM
Follow the cable backward until you find the adjusting nut. Loosen the nut. Hook the cable to the pedal assembly. Readjust the nut.
80chevybigten 03-10-2010 07:55 AM
Oh, why didn't I think of that? I got underneath it to loosen it but the threads and nut are rusted together to the point to where I couldn't turn it. Is there anything you would recommend to loosen the rust up?
fast68 03-14-2010 04:35 AM
PB blaster
and/or some heat on the nut only
vice grips
small plumbers monkey wrenches
sqzbox 03-14-2010 05:29 AM
A line wrench will help not to round off the nut's as well. :D PB blaster is good stuff if you let it work by spraying it on and letting it sit for 12hrs or more. It's not a miracle juice that works instantly, but better than WD-40.
