80' chevy c10 parking brake problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-08-2010, 09:30 AM
I have an 1980 chevy big ten model half ton with a little bit of an issue. I need it to pass a safety inspection. For that my parking brake needs to work. I know what the problem is but not quite sure on how to fix it. on the firewall just above the brights switch and underneath the dash there is a cable that fits into a bracket that sets the parking brake. Right next to the breaker. Right now the cable is not in its bracket. I tried to pull it up with pliers and I got it up a bit more. I got underneath the truck and found the cable and tried to shove it up into the cab and that helped a bit moe as well. I removed the rubber piece on the parking brake pedal so I could raise it higher so the bracket would come closer to the cable and that helped a little. But I need another 1/8 of an inch or so and I cant get it there. Any ideas on what I can do to fix this problem?
Old 03-08-2010, 09:41 AM
Follow the cable backward until you find the adjusting nut. Loosen the nut. Hook the cable to the pedal assembly. Readjust the nut.
Old 03-10-2010, 08:55 AM
Oh, why didn't I think of that? I got underneath it to loosen it but the threads and nut are rusted together to the point to where I couldn't turn it. Is there anything you would recommend to loosen the rust up?
Old 03-14-2010, 05:35 AM
fast68's Avatar
likes chevy trucks & boobies
PB blaster
and/or some heat on the nut only
vice grips
small plumbers monkey wrenches
Old 03-14-2010, 06:29 AM
sqzbox's Avatar
My pipes are my music
A line wrench will help not to round off the nut's as well. PB blaster is good stuff if you let it work by spraying it on and letting it sit for 12hrs or more. It's not a miracle juice that works instantly, but better than WD-40.
86 buick brake problem zonk Suspension - Brakes - Steering 6 01-24-2010 10:38 PM
1955 chevy with a 75 GMC IFS disc brake help hotrod389 Suspension - Brakes - Steering 2 01-08-2009 04:58 PM
58 Chevy Apache : Brake Lights / Wiring Harness Rathimis Electrical 3 12-13-2005 09:34 AM
Brake lines C10 wickedwitchinak Suspension - Brakes - Steering 4 08-07-2004 08:04 PM
80' chevy c10 fulsize truck...exhaust chevyteen17 Engine 2 02-16-2003 01:14 PM
