80 firebird hitting rear tires - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-03-2012, 10:19 PM
This car came with oversized rear tires on it, 275/60R15 actually. Under acceleration and hard cornering the edges of the fender wells hit the tread of the tires. I know the easiest way to prevent this is to get narrower tires, But I dont have the funds for that right now. I was thinking about adding a leaf to each side to raise and help stiffen the suspension. Eventually I would like to get new springs altogether. But for now would this work? Thank you for your responses.
Old 05-03-2012, 11:31 PM
theress a couple of ways to do this something as simple as getting a block of alum. or steel, fig out what size you need put that inbetween your axle and you leaf, or run coil springs, or you could replace the whole leaf spring and replace. or you could flare out the wheel well, or change the back spaceing on your rim if you have the room sometimes that works well, good luck
Old 05-04-2012, 06:21 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
It's not too hard to roll the inner edges of the fenderwells to gain some clearance, that's what I did on my '81 Camaro.
Old 05-07-2012, 08:47 PM
GMCBEAST's Avatar
My buddies '79 Bird came with air shocks on it, you could jack that thing up to the moon, plenty of clearance. Just wondering if your's might have them as well to lift that rear. They are not that expensive and easy to install if you want to go that route, but you will not have as good of traction due to lack of weight transfer with the rear sitting higher and the ride being stiffer, hope this helps.
Old 05-08-2012, 09:44 PM
I might do the roll if the extra leaf doesn't quite get the job done. Thanks for the ideas.
tires hitting Hairpins bill plise Suspension - Brakes - Steering 6 09-18-2010 10:40 PM
1988 Firebird question tires whitesephiroth Hotrodding Basics 4 08-25-2009 02:49 PM
New Firebird hood hitting the market soon! drewhelm Body - Exterior 7 02-25-2006 04:59 PM
biggest tires for a 68 firebird? ratfink14 Transmission - Rearend 4 11-17-2003 10:21 AM
69 firebird wheels with tires for sale fletch69 Transmission - Rearend 0 03-09-2002 04:50 PM
