Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 80+ oil PSI in new SBC
Old 01-28-2013, 08:58 PM
69chevyLWB 69chevyLWB is offline
Temp was in a heated shop kept constantly at 55F. never inspected relief spring in oil pump just looked at the roll pin that was installed so that the spring couldnt be tampered with. screw on filter also is stock style that has bypass in it. should i pull the pan and look at the pump and inspect or continue with break in?
