Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 80+ oil PSI in new SBC
  #24 (permalink)
Old 01-28-2013, 10:00 PM
painted jester's Avatar
painted jester painted jester is offline
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
Originally Posted by 71nova355 View Post
Hi, Hey I thought the bypass was only meant to happen cold untill the oil was warmmed up so it wouldnt have such a hard time trying to go through the filter? Are you guys talking about somthing else? not starting anything but id like to know.
The different pressure pumps have a by pass spring to keep pressure at specs for each particular pump it is the pumps brain the gears in the pump cant control the pressure. the by pass spring is in control cold or hot!
The by pass for the filter opens letting most oil by pass the filter! the filter does not filter all the oil all the time only about 10 percent during running conditions. If you block off the oil bypass all oil is filtered all the time! If you add a heavier spring the percentage goes up!
Jester
