Are you doing cam break in or are you into engine highway break in you mentioned 4000 rpm and 100# pressure and climbing?
Jester |
well i dont know what pressure is like at idle because since it is break-in i tried not to let it idle. took it too about 2500 rpm and pressure was about 80 lbs. only reason i blipped it too 4000 was to see if the bypass would kick on and if the pressure would keep rising. really thinking i should probably drop the pan and look at the pump. what should i look for when i pull it apart so i know if its the spring of whatever is wrong.
Finnish your cam break in at 2000 rpm drain that break in oil to get out the contaminants change the filter add some zddp and 10 30 oil restart and see what your oil pressure is If your engine has very close tollerances it might be a little high if you ordered a high volume high pressure pump but forgot to open the pump passage or chamfer the crank oil holes! If its an early block and your getting pressure in the rear move your sending unit to the front of your block and see what the reading is.
Jester |
hello
I have a 355 that when cold running vr1 10w-30 she is 75psi and will climb higher if im hard on it, but I usually just keep it cool or drive normal for 10-15 minuts until she warms up a lil, prolly when the oil filter bypass kicks off, and pressure drops to 60 even when pushing the car hard, and never gets below 35 real hot at a stop light. I was worried at first but everyone respectable I talked to said those were all ideal numbers and Id be fine. Let her get warmed up and see. I think anything below 100 will be ok youll just no real soon if any gaskets are leaking because youll see blowby or whatnot creeping out. NO biggie tho.
Just looked back on my order and the oil pump is a standard volume standard pressure unit from summit racing.
The by pass for the filter opens letting most oil by pass the filter! the filter does not filter all the oil all the time only about 10 percent during running conditions. If you block off the oil bypass all oil is filtered all the time! If you add a heavier spring the percentage goes up! Jester Last edited by painted jester; 01-28-2013 at 10:07 PM. |
I am currently using Lucas oil break-in oil and for the next change it will be brad penn 10w-30
The pressure relief spring and valve in the pump is what sets the oil system pressure, unless the oil viscosity/oil clearances combine to raise the oil pressure beyond the pressure relief of the pump. This assumes a correctly working oil pump pressure relief assembly. It wouldn't be a big surprise to find the pump has a different relief spring than it was supposed to have, or even that the pump valve is hanging closed. But see what you get for pressure w/the thinner viscosity oil after break in before you drop the pan.
anks, that sounds about right. Thank you too jester.
| The Following User Says Thank You to 71nova355 For This Useful Post: | ||
painted jester (01-29-2013) | ||
Your scores even 1 thanked and 1 thanks LOL
![]() Jester |
| Oil psi and not so much psi | gongchuan | Engine | 19 | 09-10-2012 07:47 PM |
| low oil psi on sbc | sweet85chevy | Engine | 7 | 02-21-2011 11:14 PM |
| Low milage rebuilt 350 SBC No oil psi I would appreciate all help thanks! | jarrodlaforce | Engine | 4 | 09-23-2010 10:37 AM |
| good oil PSI but very little oil in valvetrain | Slimpikins | Engine | 4 | 05-19-2008 11:17 AM |
| sbc 400 low oil psi at idle | camino_man | Engine | 7 | 08-01-2005 05:08 PM |
