80 vette tranny.. what swaps with the stock 3 speed in the 350? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-26-2003, 01:32 AM
jens42's Avatar
Subject just about sums it up, I have a 80 vette with stock 350 and 3 speed auto, want to know what 4 speed auto will drop in with no changes to flywheel or anything. thanks! Jens
Old 08-26-2003, 04:34 AM
mikeweyman's Avatar
Last journal entry: 2 years later
good luck bud, i swapped out the tired 400 turbo for a 350 turbo,nothing matched but the bolt holes.diffrent splines in the tailpiece, linkages, kickdown, all diffrent, and your going standard....mike. you will need a vette to swap from.
Old 08-26-2003, 08:55 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Re: 80 vette tranny.. what swaps with the stock 3 speed in the 350?
======= as your question is asked:
nothing will drop in without changes .
the 200R4 is the same length as a 6 inch tail T-350.
trans mount is in a different position on 200R4, cable shifter mount to the tranny will be diferent
I gotta sign this too?
Tony
