80s camaro/monte carlo/s10 7.5" 10 bolt rear brake offset - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2008, 09:22 PM
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 51
80s camaro/monte carlo/s10 7.5" 10 bolt rear brake offset/ axle standoff
I was wondering if someone could give me the rear brake offset specs for the 80s camaros/monte carlos/s10 7.5" 10 bolt rear ends.
I am particularily interested in the specs for the camaro specs however I am told that all these vehicals should be the same rear end.
Basically my problem is I am looking at putting an aftermarket differential in there with 2.5" brake offset/axle standoff. I am told that the stock brakes wont work. Having no money for aftermarket brakes if I buy the rear end I need the stock brake offset so if I am able to I can have a spacer made up by my buddy who works in a machine shop. This way when I do have money to upgrade I can remove the spacer and get the more common 2.5" aftermarket rear brakes.
Thanks for the info.
BiG WHiskey
TH350 and 10 bolt rear end... rezervation_pitbull Transmission - Rearend 3 10-03-2007 03:59 PM
79 TA, 10 Bolt rear end, highway gears, looking to step up Gladis Transmission - Rearend 3 04-03-2007 09:19 PM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 07:17 AM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 07:50 PM
7.5" gm 10 bolt????? Vancouver Grand Prix Transmission - Rearend 6 05-27-2003 04:49 PM
