80's G.M. horn terminal - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-03-2009, 11:53 PM
I have an 80's camaro or firebird tilt steering column in my 37 Sedan and the wiring kit doesn't identify the horn terminal at the bottom of the column. Any ideas out there? Is the horn button just a grnd ? Thanks
Old 09-04-2009, 01:54 AM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
Pretty sure the horn button is a grounding switch. So a 'hot' from a horn relay should make it's way up the column.
You could probe the contacts at the column plug with a DVM with a continuity check (beeps when circuit is completed) and press the horn button while checking the different plug contacts.
Or look up a schematic.
Old 09-04-2009, 09:51 AM
Correct. The wire from the relay coil runs up the column and is grounded when you press the horn button.
Old 09-06-2009, 01:15 AM
Thats great I'll try testing it for continuity. I tried to find a schematic but I'm afraid my internet skills are severely lacking .
Another Horn Question Chevy 84 Electrical 0 07-05-2008 03:15 AM
Replace existing horn w/ ooga horn? BobbyG-39 Electrical 14 11-03-2007 02:58 PM
I need help about GM horns..wiring aftermarket horn GMCANYON Electrical 5 04-27-2007 09:11 PM
64 Impala Horn Problem dmaggard Electrical 28 09-14-2006 01:01 AM
69 GM Column Horn Problems Campbem Electrical 7 01-01-2005 12:25 AM
