80's GM seatfoam - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-29-2011, 04:34 PM
80's GM seatfoam
We haven't found Regal (late 80's G-Body) bucket seatfoam.
There is a vendor offering Monte foam which he claims will work with modification. Does anyone have a sense of how much modification is required?
Can one swap a good passenger foam set into a driver's door?
Thanks
Dave
Old 09-29-2011, 05:51 PM
Thanks
Dave
EDIT:
Can one swap a good passenger foam set into a driver's seat?
(took me a year to find a nice driver's door apparently I'm still traumatized... )
Old 09-29-2011, 08:03 PM
seat foam
If the seats are equal buckets and not 60/40 they interchange most of the time
Old 09-30-2011, 08:20 AM
DanTwoLakes's Avatar
Wiki Edits: 22
There's no way to know how much modification is needed between the Regal seat foam and the Monte Carlo seat foam until you see both pieces of seat foam, the new one and the old one.
"If the seats are equal buckets and not 60/40 they interchange most of the time"
That is not true. Once in a while both sides, driver and passenger, use the same seat bottom foam, but almost always they are not identical. They may only need minor modification. The seat back foam may be identical, however. Once again, it depends on the seats.
Here is a link to your Regal seat foam: CLICK HERE
Old 09-30-2011, 09:20 PM
Excellent- Thanks
Dave
Old 10-01-2011, 12:05 AM
seats
My answer might have been misunderstood. I was answering the question about pass. side and dr, side interchangeable. Iv'e done this hundreds of times. When someone needs dr. seat repaired and needs their car, I just swap seats and they can use their car until I get seat repaired. Some times you have to change tracks. One is elect and other manual etc.
Old 10-01-2011, 01:00 AM
Wiki Edits: 22
Yes, that is true, almost all bucket seats can be mounted on either side of the car temporarily until the correct seat is fixed and put back where it belongs.
The best idea I've seen is in the older Toyota 4 Runner, and maybe other models as well. Those seats have interchangeable seat bottoms. You can switch the passenger side bottom with the driver's side bottom because they are exactly the same.
80's 4.3 chevy karskustoms Engine 1 04-14-2011 12:42 AM
66 Corvette 327 or 80's 350 Canuckcamaro Engine 17 03-29-2011 10:46 AM
Tall air box in 80's C10 spinn Engine 15 09-29-2010 12:35 PM
Best Forum for 80's H/O-442? SSedan64 Hotrodders' Lounge 1 07-15-2009 08:15 PM
70's 454 or 80's 454???????? inquiring_mind2 Engine 2 11-26-2007 09:25 AM
