80's trans swamp - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-23-2010, 01:52 PM
peppers's Avatar
80's trans swap
I am putting a 80's computer controlled 350 trans in a 70's non computer truck. What do i do for the conversion? I assume the computer controls the shift points. And the 70's was controlled by vacuum! Right or wrong? Thanks wayne :
Old 01-23-2010, 03:52 PM
THM 350 trans
A THM 350 transmission is not computer controled.
The only thing on a 350 that is electriacaly controked is the computer clutch.
12 volts to the solenoid socks up the converter.
You can run + 12 volts to one wire of the selonoid and run the - wire to the 3rd gear pressure switch.
You will have lock up just after the 2-3 shift.
Good luck
4x4 1994 Trans problems ???? sinlow1980 Transmission - Rearend 2 07-16-2007 07:37 PM
4t60 Trans Question david hill Transmission - Rearend 1 04-10-2007 09:58 PM
Is a TCI street fighter 350t trans any good?? tiresmoke55 Transmission - Rearend 1 03-28-2007 01:04 AM
C4 trans ident? ptsherman Transmission - Rearend 4 12-29-2004 08:27 PM
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 09:51 PM
