Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 81 camaro doesnt stop worth a darn, even with wilwoods
Old 02-01-2012, 07:58 AM
stich626's Avatar
stich626 stich626 is offline
Last journal entry: The TwoTonShu #10
whats the engine vacuum?
is the vacuum line hooked up under the throttle blades..??
is the pushrod used, the correct one for that boooster..?
was the booster and master a matched set??
is the master a manual master.. ?
is the masters bore size correct for the calp. bore size..?
do you have a 4 w disc master..?
did you clean the rotors and pads.. or are they full of oil/grease?
my bet is lack of vacuum.
