81 camaro doesnt stop worth a darn, even with wilwoods - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2012, 08:26 PM
gonzo08383's Avatar
Last journal entry: brakes
so here's what i got: wilwood d52 dual piston calipers(front), wilwood gm metric single piston(rear). new master cylinder bench bled twice, new disc/disc prop valve, new dual diapragm (7" i think)booster, stainless braided lines, new steel line all 'round. lines have been bled seven ways to sunday, pedal goes about 1/4 and gets firm but brakes suck. car stops but i cant for the life of me lock 'em up. they just slide to a stop. i dont know how to check psi on the calipers. i don't know how to measure master bore. the back of it that mates to the booster is about 1 1/2" diameter. my old one was a lil smaller than 2". almost as if the pressure isnt up to par. vacuum is about 20 inches and drops to 13-15 when braking. tried an old overflow tank to act as a vacuum reservoir but without a check valve i don't think it works right. any good ideas out there? i'm kinda broke so i'd rather not gamble on a new master if i dont have to. thanks in advance
Old 01-31-2012, 09:07 PM
Last journal entry: update
http://www.pirate4x4.com/tech/billavista/Brakes/
Old 02-01-2012, 07:58 AM
stich626's Avatar
gearheadslife
Last journal entry: The TwoTonShu #10
whats the engine vacuum?
is the vacuum line hooked up under the throttle blades..??
is the pushrod used, the correct one for that boooster..?
was the booster and master a matched set??
is the master a manual master.. ?
is the masters bore size correct for the calp. bore size..?
do you have a 4 w disc master..?
did you clean the rotors and pads.. or are they full of oil/grease?
my bet is lack of vacuum.
Old 02-01-2012, 08:38 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
Originally Posted by whyholdback
lots of good info in that link
Old 02-01-2012, 08:40 AM
brake problems
I had a similar brake problem on my '52 Olds custom It is subframed with an '87 Buick Regal sub, disk brakes. The rear is a late Chev drum. Seven inch dual chamber booster, Corvette master.
The problem was solved with an electric vacuum pump. The brakes on the Olds now react very much the same as on my late model Mercury Gran Marquis. Just light foot pressure is required. I still do not lock up the brakes...it just stops!!!
Old 02-01-2012, 05:07 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
Read through this Gonzo. I do every now and then , I still have a lot to learn.
http://www.deanoshiro.com/brakes/FAQ_brakes.html
Dont spend any money untill you read this. I am sure something will come to light.
The info you want is at the right of the page, under brake article, read them all.
Old 02-05-2012, 08:00 AM
Last journal entry: 63 split window Corvette RESTOROD
Good article, questionable guy to deal with based on this posting.....
http://forums.corvetteforum.com/tran...otrodsusa.html
Old 02-05-2012, 08:37 AM
LATECH's Avatar
Wow , that is too bad. What a bright individual. To waste all that on a botched/ misplaced order, to not fix the situation just takes away from all the work he has done to build his empire.
I would be interested in Knowing the final outcome of the deal.Post something in the lounge if you see anything, if you can.
Old 02-05-2012, 08:51 AM
LATECH's Avatar
Oh and to reply to the original post, to stay on topic here, I just ran into the same problem with a 1970 impala w/a 502 .
Pretty much the same setup too, gm front disc and calipers, wilwood rear calipers and rotor kits on a 9 inch ford rear ( Yeah..how bout it?)
dual diaphram 7 " booster, new master etc etc etc.
Seems the biggest problem was the same , inability to apply brakes hard enough to lock them up.
Turns out the pushrod angle on the brake pedal was not at the optimum 90 degrees when pressure applied was sufficient to stop the car/slide the tires.
anything more or less than 90 degrees will diminish the ability to apply force as it changes the pivot point or fulcrum which.
Seems the original installer had to mod something under the dash and ended up with a pushrod that was too short. It was about 1 1/2 inches too short.
Once that was fixed the car would skid the tires if desired.
The 7 in dual diaphrams work pretty well. We checked the vacuum supply and it seemed low (14 IIRC) due to the radicalness of the cam,but the booster was not the issue.
Dean oshiros article also clears up the power brake-non power brake master cylinder truths--myths whatever you want to call it. It points out the facts like master to slave (w/cyl or caliper) bore size to bore size ratio importance , application requirements for drum or disc, etc etc etc etc etc etc .
Old 02-05-2012, 09:18 AM
stich626's Avatar
gearheadslife
as soon as I read the dual booster, I listed the pushrod..
thats the #1 issue when changing to those
Old 02-05-2012, 09:47 AM
To be clear, Push rod length?
Old 02-05-2012, 10:01 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
He is talking about the push-rod that hooks to the pedal under the dash then runs through the firewall , then to the booster which then pushes the rod at the M/C. You must have the correct length for everything to work properly .JMO
Cole
Old 02-05-2012, 10:31 AM
LATECH's Avatar
Cole
Exactly. Also the brake pedal lever may have 2 holes at different positions for the rod to hook to. It is another thing to look for.
The distance of the hole from the point that the pedal arm hangs from , the lower the ratio and higher effort required to apply the same amount of force. Its another lever and fulcrum setup, so look it over.
holley 3310s worth a darn ? whathaveigotinto Engine 13 08-10-2010 02:51 PM
Will Wilwoods Fit?? HammerGVette Suspension - Brakes - Steering 7 11-01-2007 07:09 PM
How Much are wheels worth? Camaro badazz81z28 Suspension - Brakes - Steering 3 10-25-2004 06:50 PM
i was wondering if the tranny is worth a darn.............. CMROGRL Transmission - Rearend 11 10-16-2003 08:30 PM
6? Camaro parts worth getting??? M&M CUSTOM Body - Exterior 3 04-02-2003 04:58 PM
