My 81 chey 1/2 ton truck with 350 4 bbl starts and runs great until I floor it or accelerate. Then it seems to bogg . I changed the fuel filter changed the vacume advance diaphrm .I also changed the plugs . the exhaust seems to be flowing fine I don't think theres any restrictions. Any sugestions !!!!!
Thanks I will try your ideas and see what happens.
How many miles on the carb? I agree with you 78Monte, the accelerator pump sound like it's bad or the cam. Usually if I rebuild a carb I'll use a different hole on the pump lever just to make sure the top portion of the pump area is'nt worn that would cause problems
My '93 gmc with 350/auto does the same thing after I installed a Hypertech Thermomaster Chip and a 1" TBI spacer. My problem is probably the idle control sensor though. Your's sounds like the accelorator pump.
