81 Chevy Stepside engine swap - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 08-14-2004, 07:40 PM
Hi all
I have an 81 Chevy Stepside. I'm swapping the stock inline 6 & A833 4 speed tranny for a small block & a turbo 350. Anyone done this before? The main ? is do I need different crossmembers
or just the mounts?
TY in advance
Old 08-14-2004, 09:17 PM
BOBCRMAN@aol.com's Avatar
Have done this one several times. You will need V-8 frame mounts and TRUCK motor mount shells. Radiator from automatic truck.The rear crossmember is ok. You will also need the power steering mount from the V-8 if you retain power steering. Everything else is standard swap stuff.
Old 08-14-2004, 09:45 PM
Thanx alot
