81 cutlass motor swap for a 350 chevy motor
Hey I have a 81 cutlass supreme and I'm trying to put a 350 chevy motor in it. The problem I've run into is the motor mounts. I don't want to drill or weld. Is there another alternative? Is there a mount that matches the wholes on the frame of my cutlass that will also match the chevy 350?
I've did about five small block swaps into G bodies and every one had the holes already there for the motor mounts. As a matter of fact, if the car your swapping to came with a V8 then you can reuse the crossmember as well as the fuel lines will be on the correct side of the car, it's a very simple straight forward slam dunk swap. Also if the car came with a V6 it's very wise to swap in V8 front coil springs, if not, the front end will sag.
| 327 chevy motor in a 85 olds cutlass any ideals | Devarius | Engine | 4 | 07-07-2011 11:49 AM |
| 5.3 ls motor swap in a 72 chevy c10 | HOT ROD TWAN | Electrical | 4 | 02-03-2011 01:52 PM |
| Chevy motor mounts won't line up in my Cutlass | labreejr | Engine | 10 | 11-23-2010 05:33 PM |
| 82 Buick Regal Motor Swap To 85 Chevy 4.3 | 1badassgbody | Electrical | 18 | 09-08-2010 09:46 AM |
| Help! 77 Chevy motor swap questions! | CokeZero | Engine | 49 | 08-11-2010 07:57 AM |
