81 malibu proportioning valve - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2012, 11:00 PM
hi im wanting to no it i can take my leaking valve of the frame and get a new one and mount it on the booster/master cylinder of of ebay or will this not work thanks. it has stock brakes drums in rear disc in front
Old 06-16-2012, 01:38 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
proportioning valve
You can install an adjustable proportioning valve on the rear brake line just below the master cylinder.
Old 06-16-2012, 07:52 AM
do i need to do anything to the front line
Old 06-16-2012, 07:57 AM
bracketeer's Avatar
489 Lemans
front line
No. Most of your breaking power comes from the front. All the weight is over the front tires. The purpose of the proportioning valve is to keep the rear tires from locking up and skidding. When you install the adjustable proportioning valve. You will have to adjust it so the rear tires don't lock up.
Old 06-16-2012, 08:19 AM
ok so i can remove my junction box run streight line and a and probably a t fitting to the front and streight line plust the adjustable valve to the rear
Old 06-16-2012, 08:45 AM
bracketeer's Avatar
489 Lemans
lines
You can remove the stock valve. Run one line from master to existing tee in the front. Run short line to valve. Then a line to tee on rear differential. My preference is to use braided brake line. It is easy to work with. The racing type is cheap but not DOT approved but I use it anyway.
Proportioning Valve rusty duck Suspension - Brakes - Steering 4 07-20-2011 09:24 PM
proportioning valve mac350 Suspension - Brakes - Steering 4 09-28-2010 06:21 PM
proportioning valve fred56 Suspension - Brakes - Steering 11 12-21-2005 03:46 PM
Proportioning valve 56don Suspension - Brakes - Steering 1 05-09-2003 10:34 AM
S-10 Proportioning Valve TurboS10 Suspension - Brakes - Steering 5 01-03-2003 11:42 AM
