Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - '81 Monte Carlo DanTwoLakes Please Help with interior
Old 05-07-2013, 10:45 AM
DanTwoLakes's Avatar
DanTwoLakes DanTwoLakes is offline
Wiki Edits: 22
No, it is not two plastic layers with foam sandwiched in between. It is called "foamed" because of the manufacturing process which makes it half the weight of solid PVC. It is the same material all the way through. It is also called expanded PVC. All you need is the 3MM thickness (1/8"). There are uses for 1/4", but for panels, that's overkill.
The Following User Says Thank You to DanTwoLakes For This Useful Post:
timster2833 (05-12-2013)
