'81 Monte Carlo DanTwoLakes Please Help with interior - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-06-2013, 04:26 PM
I've been reading through the interior threads since I joined and have figured out pretty much what I need to do and what I need to buy. I have a 1981 Monte Carlo and I am going to reupholster the interior with black marine grade vinyl. I have a gallon of the Dap contact adhesive Dan suggests in every thread and a bunch of cheap throw away paint brushes to apply it. I'm making new door panels from scratch using pvc foam as suggested. This is where my first problem comes in, I went to a local sign shop and they said they have Kometex but when they showed it to me it doesn't look how it is described. It has the pvc on the outside, but rather than a foam in the center its a hard plastic like material. They did have another material that the worker was unsure of the name but it had a dense foam in the middle and a very brittle plastic on the outside. It didn't seem to sturdy, more floppy for lack of better words. Please let me know if any of this sounds right or what I should be looking for? Also I'm going to document me interior build in this thread so please stop back with any insight or comments. Thanks in advance -Tim
Old 05-07-2013, 07:26 AM
DanTwoLakes's Avatar
Wiki Edits: 22
PVC foamboard is solid all the way through, so they didn't show you the right product. It is also called closed cell PVC, and foamed PVC. Sintra, Komatex, CelTec, and Palight are brand names, and I'm sure there are more.
Old 05-07-2013, 08:15 AM
So the komatex looks like plastic all the way through? They have that I just thought it looked wrong because I didn't see foam in the middle. Next question is, they only carry 1/4", they can order 1/8" am I better off with one size over the other?
Old 05-07-2013, 09:45 AM
Wiki Edits: 22
No, it is not two plastic layers with foam sandwiched in between. It is called "foamed" because of the manufacturing process which makes it half the weight of solid PVC. It is the same material all the way through. It is also called expanded PVC. All you need is the 3MM thickness (1/8"). There are uses for 1/4", but for panels, that's overkill.
The Following User Says Thank You to DanTwoLakes For This Useful Post:
timster2833 (05-12-2013)
Old 05-07-2013, 11:02 AM
Thanks for explaining it! I'm gonna order the 1/8" affter work. They want $50 for a 4x8 sheet. Next question is about how much vinyl would you use on a car like this to upholster everything. All the plastic trim, dash, 2 buckets and 1 bench seat, trunk and door panels. Just a guess.. I bought 2, 10 yard rolls amd if that's overkill is like to take one back.
Old 05-07-2013, 11:22 AM
Wiki Edits: 22
20 yards is a little high, but you'll need more than 10 yards, so it's better to have too much than not enough.
Old 05-07-2013, 12:06 PM
Ok thanks, I'll update with pictures as soon as I get the material in and get started.
Old 05-08-2013, 06:49 PM
I just bought a set of Procar Elite Series 1100 Seats, anyone have any ideas of what to use for seatbelt guides?
Old 05-12-2013, 08:38 AM
Ok, here's my next question... I bought a molded carpet for my car, it comes with jute padding attached to it. What should I do to the floor before installing the carpet? Also do I just lay the carpet down or do I glue it down? THanks
Old 05-12-2013, 10:55 AM
Wiki Edits: 22
Obviously, if you want to put in a sound deadener of some kind, now is the time to do it. If it's a good quality jute pad, you don't have to add anything else as far as padding. If it lays flat, you don't need to glue the whole thing down, but on trouble spots like next to the trans. tunnel, you might want to glue it.
Old 05-12-2013, 10:59 AM
Ok, any recomendations on sound deadening material? Also what type of glue should I use for the carpet? I have the dap top and trim that you recommend, will that work for the carpet?
Old 05-12-2013, 11:03 AM
Wiki Edits: 22
You can pay anything you want for sound deadeners like FatMat, Dynamat, B-Quiet, etc. Look for some that is butyl based as opposed to asphalt based. It will handle the heat better if you're in a hot climate.
You can use the DAP top and trim contact adhesive for anything inside your car and out.
Old 05-12-2013, 04:56 PM
What do you think of this for a sound deadener and do you think 100sq ft. is enough for an entire car? 1 New Bulk Roll Mat 100 sqft Butyl Rubber Use as Auto Sound Deadener Material | eBay
Old 05-12-2013, 07:24 PM
Wiki Edits: 22
Remember, you don't need to cover every square inch of the car, especially the trunk, roof, and fenders. That is a very good price, and seems to be a good product. It is butyl based, so I don't think you can go wrong.
Old 05-12-2013, 07:29 PM
Ok, I thats what I'll get then. Where and how much do you put it? It's a silly question but everything that I've read so far is conflicting. I've read everything from use it on the inside of the door skins as well as behind the door panels as well as every inch of the car to small strips here and there.. Can you shed some light on this? BTW. Thank you for all your help!
4th gen monte carlo ss interior mods strokermax Interior 3 02-05-2013 09:09 AM
75 Monte Carlo Interior david-b Interior 2 06-24-2011 02:47 PM
monte carlo interior F3RR3T Interior 2 08-23-2007 05:32 PM
Monte Carlo interior chrismenigoz Interior 2 12-26-2005 12:26 PM
81 MONTE CARLO E.T. J T HARLEY General Rodding Tech 6 04-05-2003 01:09 PM
