81 MONTE CARLO E.T. - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-05-2003, 10:48 AM
Post 81 MONTE CARLO E.T.
I have an 81 monte carlo ,i run in bracket. last year it ran a best 9.78 at89.27 in the 1/8 with a stock 350 bottom end with high milage,305 small valve heads ,headers dual plane intake 750 holley vac. secondaires lunati lk112 cam 4.11 gears 2200rpm converter 28inch tall street tires. the underhood of car has been gutted as has the interor to save weight.it just has a summit racing seat. the engine for this year is 350 four bolt .60 over with 10 to 1 flat tops ,alum. g m fast burn heads with 2.0/1.55 valves,cam is flat tappet dur 254/264 at .50 lift int .533 ex .555 lifts 114 degree lobe cen. it has 1.5 roller rockers weidland single plane intake with 750 holley double pumper and 1 in spacer.gm pink rods and steel crank turned 10 10 its been aligned bored and balanced.3500 plus converter built 350 trans. 411 locked rear end,hooser 9 by 31.5by 15 slicks ,e.t. 27.5 by 4.5 by 15 front tires an racing alum. wheels. elec water pump ,no alt. what kind of 1/8 et can i expect from this combo. thanks jt p s left out important imfo. plan on shifting at about 7 grand. thanks
[ March 05, 2003: Message edited by: J T HARLEY ]
[ March 09, 2003: Message edited by: J T HARLEY ]</p>
Old 03-05-2003, 11:07 AM
Tazz
Thumbs down
<img src="confused.gif" border="0">
Old 03-05-2003, 04:31 PM
Canzus's Avatar
a red wool sock on his dinger
Post
I'm gonna put a little money on
about a 9.78 at 89.27...in the 1/8th...
[ March 05, 2003: Message edited by: Canzus ]</p>
Old 03-05-2003, 05:33 PM
71montebbc's Avatar
Post
And no aero-dynamics, or rear spoiler.
Old 03-05-2003, 05:42 PM
Post
Is there a point to this question other than.......................?
Old 03-06-2003, 04:47 PM
Canzus's Avatar
Post
[quote]Originally posted by bukweet:
<strong>Is there a point to this question other than.......................?</strong><hr></blockquote>
He's just dreaming, no point at all...
Old 04-05-2003, 02:09 PM
ztoy's Avatar
speed freak
Post
sounds like a lotta stuff......
