81 Pontiac Lemans R.E. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-30-2003, 06:25 PM
jcarter's Avatar
I got this r.e. toput in my 39 Chevy . It's 52" axle flange to axle flange. Will this be the same as a Monte or Nova of that age range? It looks like the axle housing is slightly smaller than a 10 bolt out of a 81 Caprice that I also have.The Caprice looks like it would be to wide. The Lemans was just a 4.4 L or 267 and turbo 350, so r.e. could be lighter.I'm just building a nice cruiser, so don't need a big tough r.e. Was even thinking about using this complete powertrain in my 39. Any thoughts on this r.e. would be helpfull. Thanks.
Old 10-30-2003, 11:22 PM
dh79's Avatar
Most G bodies (what you have) came with a 7.5" 10 bolt rear end. The monte SS and grand nationals got the much stronger 8.5" units. Caprices have a 8.5" but they have longer axles than the G body rear ends so they won't fit (without mods).
The 7.5" aren't very strong. If you'll be keeping a stock or mild engine, it'll be just fine. If it'll run in the 13's, time to move up to a 8.5". The only real advantage of the 7.5" is that they're plentiful and cheap.
dh
