81 Spindles fit a 71 Chevy Truck? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-21-2008, 10:43 AM
Will the front Spindles off of an 81 chevy fit a 71 Chevy?
Old 05-21-2008, 03:20 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
Not a true interchange. The tie rod hole is a bigger taper on 73 up spindles. There "may" be a difference in ball joint tapers, but you can find out by asking the local parts store if the joints are the same part number.
Someone makes tierod adapters for that swap, but I don't have the info.
Old 05-22-2008, 12:01 AM
Thank you I will have to check into it.
Old 05-22-2008, 01:29 AM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
F&J is correct, 73-ups are bEEger.
Old 05-23-2008, 07:45 AM
I put the spindles on my 68 GMC. I changed ball joints and tie rods though.
Good luck!
Ryan
Old 05-23-2008, 09:46 AM
What did you do when you changed the ball joints?? I am sure I would just use the one for the 81, but on the ball joint side is it different or does it fit the A-arm?
Old 05-23-2008, 10:20 AM
I am not 100 percent sure....it was about 12 years ago, but I beleive I used the ball joints from the same year vehicle I used the spindles.
Old 05-23-2008, 10:10 PM
cool I was hoping they would fit with reasonable modification. I was more worried that the outside diameter of the ball joint shaft would be too large or too small for the inside diameter of the spindle. The tie rod would just be a screw on screw off type of thing......I believe.
Old 05-23-2008, 10:22 PM
I think the tie rods are not the same size. I know they're different on a '69. Check over at www.67-72chevytrucks.com/vboard and you'll find out all you need to know. One of the board vendors should have an adapter for the tie rods if you need one.
Old 05-24-2008, 01:40 AM
cool thanks for the link I didnt even know there was a boardjust for my truck...
1953 Chevy Truck Vin Help Homeseller Hotrodding Basics 14 08-12-2012 09:24 AM
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Engine build ideas Rug Engine 23 12-25-2006 01:39 PM
Modified 1958 Chevy spindles Radical1958 Suspension - Brakes - Steering 0 06-14-2003 10:54 PM
High Rise Cowl Hood for '81 to '87 Chevy Truck Venusfly Body - Exterior 6 11-02-2002 02:40 PM
