Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 81 z-28 repaint need help
Old 01-22-2007, 01:06 PM
stevej068 stevej068 is offline
recently purchased an 81 z-28 camaro body is decent paint is not .
the paint appears to be org. has alot of flaking and check cracks
using 6in d.a sander what would be best grit to start with . and finish with before primer . front nose has some deep scratches any way to repair this has the ( plastic ) front . or any leads on a used nose in good shape . what paint should i use lacquer or some type of enamel . was going to use lacquer to keep bugs cats etc out of paint does the newer enamel or urethane dry very fast
also looking for good place to buy supplies .
thanks steve
