'82 Camaro Flasher Location? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-08-2003, 11:37 AM
Post '82 Camaro Flasher Location?
That's it. Emerg. Flasher in "convienience consol" but t/s flasher I can't find. Nodata says left of dash, but no can find t/s flasher. '82 Berlinetta
TIA, Vaughn
Old 03-10-2003, 01:24 PM
banned
Post
I reccomend you pick up a chiltons repair manual. About 20 bucks but it makes alot of sense out of the wiring mess in these cars
Old 03-11-2003, 03:10 AM
awsum34's Avatar
Post
The turn signal flasher is located inside the convenience center. To gain access to the trun signal flasher, It mat be necessary to frist remove the under dash padding. Your convenience center should swing down. ( it should be on the left side of you sterring column).
Old 03-11-2003, 03:11 AM
awsum34's Avatar
Post
Forgot one thing. the All silver one is your turn signal, and the one with the yellow or green striping should be the 4 way flasher
