82 chevy engine rebuilding? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-11-2010, 09:52 PM
i am rebuilding a 82 chevy 305 and i pulled my piston to replace rings and i dont know if there is a certian order the pistons should should go in. and which order the parts that go around the crank, where the rod bolts together.(the ones whith the "x" first?
Old 10-12-2010, 12:26 AM
327NUT's Avatar
Just a word of advice and no offence meant...if you really don't know these basic things get someone that does know to help you.
Old 10-12-2010, 12:45 AM
BigRoy1978's Avatar
If you dont know what order it all came apart, and which part goes in which cylinder...your in trouble.
i think you're talking about the rod caps. If they dont go back on the EXACT rod they came off of...you're also in trouble.
Old 10-12-2010, 01:49 PM
sbchevfreak's Avatar
Licenced Automotive Technician
X2! If you mess up rod caps, ect., your engine will not live long.
Old 10-12-2010, 06:56 PM
thats true but the best way to learn is to do it. i got the engine for free so i was goin to try to rebuild it. now i know for next time
Old 10-12-2010, 09:38 PM
If you have mixed up the rod caps, and such, you might as well go in for a full rebuild. You could have them bolted together and resized, but a set of rods for a 350 is pretty cheap now. If you are going to do the whole thing, do you have a plan in mind for HP and TQ goals? Start with that, and you can ask questions and read/learn the techniques and skills needed to get you there. Everybody messes up at least once, some of us many more times than that. If you aren't afraid of it, and have someone to hel out when you are stumped, dive in. It may take a while to fininsh, but you will have learned a ton in the process. One of the big things is don't rush. Take your time, measure twice, three, four times and cut once Speed will come with experiance.
For the next one, buy a set of number stamps to mark the rods and caps before you take them apart. Saves some aggravation when it is time to reassemble.
Any problems with rebuilding a burnt down engine? rajsid Engine 17 04-06-2010 05:47 PM
Chevy 505 Mark IV Engine? 71gtx Engine 3 04-06-2009 03:44 PM
pontiac engine to chevy tranny... markzepp820 Transmission - Rearend 7 03-13-2009 08:49 AM
305 engine rebuilding Cerry Hotrodding Basics 26 01-06-2009 01:04 PM
350 Chevy Issues engine trouble... Please help me! ineedspeed Engine 26 07-28-2008 04:23 AM
