82 Chevy Truck change to small pattern
Can you guys tell me a way to put my small chevy car pattern wheels on the 5 by 5 truck ? Is there any 4 and 3 quarter small Chevy hub etc that I can install on the front of truck? Any help is appreciated .
I have alot of mag wheels to fit car bolt pattern.
The dual bolt patterns I find are usually small Ford and small Chevy combo. I have some old aluminum slots straight small Chevy and then I have some of the above mentioned; and also have Centerlines ,same deal ; have small Chevy ,and combo small Ford, Chevy patterns. Had the truck two days and itching to put mags on it. The rear hums some and Im thinking of changing it out. I have a couple 9 inch Lincoln disc-brake rears ; same pattern as the truck : 5by5 inch and also 80 Trans Am 8.5 posi , 256 gear . Lincoln gear is about same ; no posi. I like the high gears , so thats fine. Now which rear do you guys think I should go with . Ill have to measure lenghth of truck rear and then the others unless someone might know already. I think the Lincolns are the big ,late 70s models . Thanks Musky 2
Choices
The Versi was a POSI rear and the gears where 2 something. I had a junk yard build me one with posi and 342 gears. I hope to change out my tranny to a 700r4 next month. But I have always like a posi in a truck. As for RIMS, there are lots of choices. You just need to pick one. Post a picture when you have time.
hr41pearl
I dont have a Versaille , the two I have are the wide Lincolns . What spindles and hubs from small Chevy pattern or what donor car to replace truck pattern? Thanks
Junk Yard Dog
You should call your local wrecking yard and ask them what they have. You need to be very specific as to what you are currently running. They are very useful. You can then decide if you want buy new or from them. Example. They where able to take my rear axle and change it to 342 gears, add posi, and disk brakes. I am sure they could have changed the pattern also, if I wanted. Made lots of good friends roaming around junk yards.
hr41pearl
Chevy truck wheel pattern change
Your V ersaille 9 inch rear is easier to work on than the Gm 10 bolts . I mean I can get any rear I need reasonably ; just cant decide which one to go with . Im not going to buy new wheels so I have to use the ones I have. What about having a machine shop drill axle flanges for a small Chevy wheel pattern ? ; and same to front rotors and hubs. Thanks
Junk Yard
I just talked with the guy over at the junk yard that I use the most. They have axles stacked to the ceiling. If you call one near you, I bet they are the same. Tell them what you have in the rear and they can sell you a set for your bolt pattern. They can also tell you what to use for the front aframes spindle. I had the Lincoln in my 41 pickup and they sold me the axle to go current pattern, yet truck diameter. I think they only charged me $100 for the pair. I converted the 41 to IFS and had several spindle choices from various manufactures. Again, I could have gone to the yard, but I decided to go tube with Wilwood brakes. If you can't find a yard near you let me know what you have and what you want. I can call the ones I use.
hr41pearl
Tthom , thanks for all the info ; let me figure out what Im going to do. I didnt know you could change axles ! I guess if I find one that are same length and end axle bearing it would work.
