82 corvette hard to start,won't idle cold & lousy mileage - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 02-19-2012, 08:25 PM
my 82 vette which use to get 25 mpg now gets about 9. i've replaced the temp sensor & upgraded to a jet chip. i subscribed to ask.com & attempted to check electronics per their instructions. other than the problems i mentioned , she performs normally. i live in the desert in se. nm. so the availability of talented local help is limited. i would consider going to carburetion if it would fit under my stock hood
Old 02-19-2012, 09:02 PM
Well for the idle spraying a can of intake cleaner on the butterfly
where the mass air flow sensor is located helps. The carbon buildup
messes up the sensors readings and causes lots of problems.
Hold the butterfly open and spray away. You should be able to see where
the MAF sensor is so spray like half the bottle on it.
Old 02-20-2012, 10:13 AM
EagleMark's Avatar
GearHead-EFI.com
You can also ruin a MAF sensor by cleaning it improperly...
That is a very early and now very old EFI system. Before you start throwing parts at it I would get something to read engine data to see where the problem lies. Yes it could be MAF, or CTS sensor or a lot of other things like fuel pressure to high, blocked return line causing pressure to high or bad O2 sensor.
Do you have any CEL or error codes stored?
If you have a laptop, you can buy or make a cable and use TunerPro, free to try and only $39 to buy. All definitions are free. So once you get to using it on one car you can use it on others as well with out more costs per car!
Old 03-09-2012, 07:15 PM
MAF sensor ???
I looked beneath the throttle blades & did not find anything that looked like a sensor. The parts clerk @ my local O'reillys looked up my 82 vette & said they do not have a MAF. Wassup!!!
Old 03-09-2012, 07:19 PM
LATECH's Avatar
So it is a crossfire injection system right?
Old 03-09-2012, 07:39 PM
LATECH's Avatar
put a scanner on it,look at the datastream and trouble codes (if any)
diagnose any trouble codes that arise. Then look at the data stream for anything that doesnt jive. Sounds like a CTS problem or possible MAP sensor, not to be confused with MAF sensor.
Also the ECM can substitute a value for a sensor that has an issue or fails, also it will use a value that was its last known good value if the corresponding circuit in the ECM fails as well.
My third guess would be a defective ECM...however dont just throw parts at it. Take a look at it and post back here what you have found.
Myself and/ or eagle mark are well versed in MEE as well as a handfull of others around here... and can help.
Old 03-09-2012, 07:47 PM
yes it an all original 82 vette which all had cease-fire injection
Old 03-09-2012, 11:05 PM
EagleMark's Avatar
GearHead-EFI.com
I think your using a language translater?
Well if cease fire is same as cross fire it has 2 one barrel TBI units and would use a MAP sensor.
Old 03-10-2012, 06:19 AM
LATECH's Avatar
Hee hee... I see he has created a fond new "nickname" for his EFI.
When at the dealer, we commonly reffered to them as "campfire injection"
I understand the reason for GM going to this setup, but later setups like the Tuned port work much better.
Old 03-12-2012, 06:36 PM
if my 82 has a MAP sensor, where is it located ? I see nothing below the throttle plates in the intake manifold [ plenum]
Old 03-14-2012, 12:16 AM
i'm very familiar with your problem and the injection system on your car, do you have a hard time starting when cold? how does the engine respond when it's cold? does it run better cold or hot?
the most common problem with this system is a small hose inside the fuel tank, it goes between the pump and the feed line to the engine. the hose will rot out and get a small pin hole in it, it makes the car hard to start cold, respond bad and get horrible fuel mileage. pm me if you need more help. crossfire systems are very simple minded and it doesn't take much to make them run bad.
Old 03-14-2012, 06:41 AM
T-bucket23's Avatar
Wiki Edits: 26
I have seen several of those with rotted vacuum lines as well. Before you go getting in to deep, check over all the vacuum lines for cracks or rot.
Chet
Old 04-06-2012, 09:56 PM
good advice !!! after a year of sweating this problem , it was a broken vacuum connection @ the map sensor . thanks for the help!!!
Old 04-07-2012, 11:43 AM
T-bucket23's Avatar
Wiki Edits: 26
Glad I/We could help. I am actually looking at an 82 myself right now. Similar issues and the guy just wants to dump it. I havent looked at it but he is so frustrated he might let it go for a grand. I will fix it and it may be my wifes summer car.
glad it worked out for you
Chet
Recent Modern Electronic Engines posts with photos
Carbed ls motor hard to start hot or cold sherman8r Engine 8 08-31-2012 04:17 PM
87 gm tbi hard to start when cold chevyAL Engine 4 01-14-2010 04:14 PM
Easy cold start, hard hot start dedub Engine 34 08-13-2008 05:21 PM
400 hard to start when cold zoc65 Engine 5 06-24-2008 07:56 AM
hard cold start akm Engine 19 05-16-2004 10:46 PM
