82 cutlass - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2013, 06:17 PM
82 cutlass
Hi all, hey just trying to gather some info on my car. Its a 1982 cutlass supream , it has a 350 with a th350 , 3000 stall. Now the rear end is stock and I have no clue how to tell what I have , I want to order a gear set and a posi off summit racing but need to know the info on the diff.Just wondering if some one knows anything on these, I am sorry for asking a question with out much info attached , the rear end has 10 bolts on the cover
thanks in advance
Old 02-26-2013, 06:22 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
This should clear it up for you.
Old 02-26-2013, 06:33 PM
Hey, thanks so much for the reply it really helps out , I have the 7.5 rear
Old 02-26-2013, 07:31 PM
big gear head's Avatar
High Performance Rear Ends
Yes, you have the 7.5 rear end. All of the '78 to '87 G body cars got the 7.5 rear end with 26 spline axles except the GN, T Type and a few 442s.
I'd like to recommend the Eaton Posi or Yukon Dura Grip. I would also like to warn you that the Auburn is a piece of crap and you should avoid it. I also recommend going to Randy's Ring & Pinion or Tom's Differentials for rear end parts instead of Summit. You will need a good installation kit to go with the parts that you want and these 2 places have the best installation kits and very good prices on the other stuff.
Also check your axles before ordering anything. It is very comon for the axles to be worn where they run in the bearings. If your axles are worn then you need to replace them. You might as well upgrade to 28 spline axles while you are doing this. 28 spine parts don't cost any more than 26 spline parts, and they are quite a bit stronger.
Old 02-26-2013, 09:03 PM
vinniekq2's Avatar
might want to buy a bolt in complete rear end. depending on total costs.when you order a complete diff,you also choose what ratio it comes with
My friend Mike got a complete diff for his 86 Monte Carlo with gears and pose for $1200.บบ
Old 02-26-2013, 09:27 PM
Banned
this...
also vendors make upper links so you can install a 68-72 g.m. a bodt(chevelle) 12 bolt or the unloved in some circles 10 bolt..
Old 02-27-2013, 08:40 AM
What engine do you have? The only factory V8 engine available in the Cutlass after 1979 was a 307.
John
Old 02-27-2013, 08:46 AM
Hey thanks Big Gear Head I checked out those sites and am going to order from toms I think. Hey I forget is 373 lower or higher then 308?.
Hey Vinni do you by chance know were he got the bolt in, cheapest I can find is 2200
The motor is a 350 edelbrock aluminum heads , comp 270h cam, roller rockers
Old 02-27-2013, 09:34 AM
vinniekq2's Avatar
PM me ,My friend Mike is in a retirement home,he has M S. I am do to call him anyways
Old 02-27-2013, 11:18 AM
Moser makes a bolt in 12 bolt. If you can find a GN or T Type rear end they are the 8.5 10 bolt, which is quite a bit stronger than the 7.5. They are expensive, but cheaper than the 12 bolt.
The 7.5 uses a 2 series differential for 3.08 to 2.14 gears, and a 3 series for 3.23 to 4.56.
Old 02-27-2013, 05:07 PM
The Auburn works fine unles you abuse it. Then they wear out much quicker than the Eaton or Dura Grip and fill the rear end with powdered metal, which ruins the bearings. They also can not be rebuilt and are scrap metal when they wear out. I've had to change out too many Auburn differentials that lived a very short life. Two of them less than a year. And along with changing the differential you have to completely disassemble the rear end and clean out all of the metal sludge in the housing and replace every bearing in it. Then there is the one that exploded and busted 3 holes in the rear end housing. That whole rear end had to be replaced.
Old 02-28-2013, 08:47 AM
Hey just a update , going to pull the axles out today to see if they are ok or not , then I think I will be going with the yukon gear posi , and richmond gears 373 , what do you guys think?
Old 02-28-2013, 09:38 AM
Good choice. Get the Yukon installation kit with Timken bearings too.
78 cutlass workman306 Introduce Yourself 2 11-27-2010 03:52 PM
86 cutlass smokeyj Transmission - Rearend 3 04-03-2009 05:46 AM
75 cutlass uph98021 Body - Exterior 2 03-05-2009 01:16 AM
68 cutlass whiteboyjay Electrical 1 07-04-2007 03:49 PM
cutlass help TWOPLYM Engine 3 07-12-2005 06:12 PM
