-   -   82 elcamino slips when maually put in 1st, 2nd, or drive but takes off fine from OD (http://www.hotrodders.com/forum/82-elcamino-slips-when-maually-put-1st-2nd-drive-but-213195.html)
sanawa 01-24-2012 03:36 PM
i just installed a 700r4 with a shift kit at first i could shift through the gears if i did it manually but didnt want to go through the gears on its own. i got a tranny line leak so i replaced the line and filled with fluid and then tried to drive it but when put in 1st, 2nd, or drive it slips bad but when i put it in OD it will take off great :confused:
