82 elcamino slips when maually put in 1st, 2nd, or drive but takes off fine from OD - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-24-2012, 02:36 PM
i just installed a 700r4 with a shift kit at first i could shift through the gears if i did it manually but didnt want to go through the gears on its own. i got a tranny line leak so i replaced the line and filled with fluid and then tried to drive it but when put in 1st, 2nd, or drive it slips bad but when i put it in OD it will take off great
It takes all kinds forestrytodd Hotrodders' Lounge 2 09-10-2009 01:56 PM
Grit - how fine is too fine for adhesion? cboy Body - Exterior 41 06-28-2009 04:20 PM
Starts fine but once in drive wants to die LXZ590 Engine 8 12-08-2006 04:31 PM
tow truck takes a hike bullheimer Hotrodders' Lounge 2 01-28-2006 10:24 AM
It Takes A MoPar.... BigBlockBabe Hotrodders' Lounge 5 01-25-2003 02:52 AM
