82 monte carlo - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2010, 05:21 PM
82 monte carlo
headlights, power locks interior lights all not working. fuses are good and i just installed a knew head light switch. what could be the problem.
Old 01-30-2010, 05:28 PM
ericnova72's Avatar
More for Less Racer
Possible blown fusable link in the power feed in the engine side of the firewall wiring harness coming into the fuse box.These fusible links are usually in the primary feed wire coming up from the battery connection post on the starter. Have you probed with a test light to see if you have power to the headlight switch?? Should be power here at all times, hot from the battery. The items you mentioned are all on a full time hot feed, not controlled by the ignition switch. These items are not on fuses in the fuse block.
Old 01-30-2010, 05:37 PM
no i havent.
Old 02-03-2010, 05:25 PM
my friend did a tester on on the light sockets and there was no power to the headlight sockets. should i take it to the shop.
Old 02-03-2010, 06:07 PM
Wiki Edits: 27
check first
I bought an old caddy to get the 472 for my saw mill.it ran poorly and it had similar electrical problems. turns out the battery cables to the starter was loose. Check out all the battery cables and connections and other items suggested.
Old 02-04-2010, 04:32 PM
thanks will check that out also.
Old 02-08-2010, 10:40 AM
found the problem. it was the fusible link to the starter had burned. problem fixed. thanks to all that tried to help me out.
Old 02-08-2010, 10:34 PM
ericnova72's Avatar
More for Less Racer
Glad you got it fixed Score one for me
50 Ford F1 w Monte Carlo Clip joe123 Suspension - Brakes - Steering 5 05-26-2008 06:48 AM
82 monte carlo rearend question 82montecarlo Transmission - Rearend 3 07-02-2007 10:31 PM
ok lets see how many monte carlo people agree monte mike Hotrodders' Lounge 25 11-19-2006 05:09 PM
Bring Back the RWD V8 Monte Carlo!! Fragzem Hotrodders' Lounge 18 10-17-2004 12:35 AM
'82 monte carlo wiring diagram jwash56 Electrical 0 05-09-2004 01:07 AM
