82 monte carlo rearend question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2007, 01:24 AM
i think the rear is stock the question is when i sit a stop sign an do a breaktork i only leave one line so one tire spins how do i get that to stop when i leave marks i wanna leave both not one ... is it the rearend? trac control?
Old 07-02-2007, 01:45 AM
j.d.brown.042964's Avatar
406 Caprice:Rust Never Sleeps!
You have an "open" type differential, and would need to change to a "posi" type to have both wheels powered. There are many different types, but easiest to find and most affordable are stock gm 10 bolt. Search the knowledge base if you want more detailed information or explanation of different types of posi rearends.
Old 07-02-2007, 08:34 PM
mini spool
look in jegs,they offer a few mini spools.Its a cheap way to go.
Old 07-02-2007, 10:31 PM
leldai73's Avatar
Its just metal,you're the boss
spools are a bad idea on the street. do a search on the subject, it has been discussed extensively.
what you have is a 7.5 inch 10 bolt. these axles aren't known for their strength but with less than 300 foot pounds of torque and a nice driver they will live for a good long time on the street.
as stated earlier you want a "posi" or positive traction rear end. you can buy various units from jegs or summit including "lockers" that lock and unlock by themselves as you go around turns, noisy but effective. and install them in your axle
or you can do some hunting in a junk yard for one. your going to need a rear end from either a Monte Carlo, regal, grand am, cutlass or grand national maybe some other full size Chevy's of that era. look for the grand national, some came with the 8.5 ten bolt, a much better axle. good luck though, they are like a needle in a hay stack. the monte carlo doesn't lend its self well to adapting strong axles at 57 3/4 inches wide its narrower then most, and the brackets are complicated.
to determine if an axle is a "posi" look for a tag hanging on the differential cover that says something like "use only limited slip gear lube". this tag is often gone so, to be sure lift the rear tires of the vehicle off the ground and with the transmission in park or the yolk held from turning spin one tire. if the other tire spins the same direction its a posi, if it spins the opposite direction its open.
What will this 12 bolt rearend from 71Monte Carlo fit? shockers69 Transmission - Rearend 4 04-23-2004 09:54 PM
How Big Of Tire Will Fit A 85 Monte Carlo 406 ss monte Suspension - Brakes - Steering 2 02-26-2004 07:35 PM
9 inch ford under a 86 Monte carlo HELP ME! ss crazy Transmission - Rearend 11 01-23-2003 06:35 PM
monte carlo v6 rear end ? 85irocss Transmission - Rearend 1 08-22-2002 03:11 AM
74 Monte Carlo bigjoedo Hotrodders' Lounge 1 02-25-2002 11:14 PM
