82 trans am suspension prob - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2004, 08:21 PM
New Member
on my 82 ta the pass side tire hits on the inner fender when i turn the wheel right when i go left it dont hit the car is undrivable its thumping and i cant go over like 10 i replaced the ball joint and tierods and it still does it tires are 15 in so thats not the problem any thoughts?
Old 04-09-2004, 08:04 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Trashed steering box.
Old 04-09-2004, 01:15 PM
New Member
ok i was looking at it again today i dont see anything bent or anything but when i push down on the front to bounce the car as to check the struts it is very stiff and wont move the drivers side moves like it should the struts were replaced before i got the car but is it possible that the strut got bent or is frozen or could it be a bad coil spring would any of that cause my problem
Old 04-09-2004, 03:35 PM
New Member
actually the strut is good i forgot to let my jack all the way down that was causing the bind still having the tire issue anymore suggestions?
