Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 83 buick 231v6 with Rochester dualjet
Old 07-21-2012, 04:35 PM
83 cutlass 83 cutlass is offline
No the check engine light has been doing this since as well mind you this is a rear whleel drive cutlass turn the engine over thw light fashes and ends with the same code then stops flashing until key is tuned back and engine resarted then repeats and when driving no also i believe oil pump is worn out low oil pressure at ligh
tz by light and guage
