83 buick 231v6 with Rochester dualjet - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
  #16 (permalink)
Old 07-22-2012, 01:33 PM
LATECH's Avatar
Last journal entry: New Gas Tank
No. float adjustment as well as most of the others are made with carb opened up. Fine tuning can be done by accessing adjusters through some of the holes in the carb.
Have you checked the base tining?
Fact is stranger than Fiction
  #17 (permalink)
Old 07-22-2012, 07:44 PM
Thanks to your great help i decided to open the carb up only to find you were correct the adjustment screw was 2 full turns below what the chiltons book specified no thanks 2 national carbuertor sometimes your better off to do it yourself ehh? I did also discover i may have a blown head gasket on one side due to the factho t i just put new plugs in the thing even though the previous owner had sworn hed put new plugs in well in my search to find answers i discovered that cylinder 5 has some pitting on it around the base is this a for sure sign or could this be from bad valve guides some sort of oil seepage it wasa little bit of white ash on the very tip thanks again latech
  #18 (permalink)
Old 07-23-2012, 03:16 PM
LATECH's Avatar
Youre welcome...
Recent Modern Electronic Engines posts with photos
need help ,rochester dualjet milan-ranflero Engine 2 11-29-2011 06:00 PM
rochester dualjet help hcker2000 Engine 10 12-27-2007 12:32 PM
How metering rods work in Rochester Dualjet ? Olds 69 Engine 1 02-18-2005 02:56 PM
who knows something about rochester dualjet 210 carbuerator diAMID Engine 0 09-14-2004 02:36 AM
rochester dualjet 210 oakland_raiders Engine 4 01-03-2003 07:58 PM
