83 ford brake master cylinder leaking - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-23-2008, 11:52 AM
Hi, i have a 1983 ford f-150 and the master cylinder is leaking where i bolts to the brake booster, is there a seal back there or how does it seal between the two. Thanks, Jake
Old 10-23-2008, 12:01 PM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
Yes, there is a seal at the rear of the master cylinder. A leak in the area you described is the most common indicator of that seal leaking. You should either rebuild or replace the master cylinder. The booster should be fine, just clean it up well when you have the master cylinder off.
power brake booster and master cylinder ? Area_51 Suspension - Brakes - Steering 9 02-05-2008 01:30 PM
Master cylinder brake line questions Stroker56 Suspension - Brakes - Steering 5 04-27-2006 08:40 PM
Dual Master Cylinder Brake Pedal with Balance Bar iceman36 Suspension - Brakes - Steering 6 02-24-2006 12:55 PM
Master Cylinder Leaking 70SPORT Suspension - Brakes - Steering 1 05-25-2004 02:51 PM
master cylinder differences 56don Suspension - Brakes - Steering 2 12-30-2002 08:23 PM
