83 jimmy fullsize won't stay in 4x4 high - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2008, 03:25 PM
dikki706's Avatar
i went out on a poker run in az and when i would put the trans case in 4hi it would engage and then would pop out during any rough patches. my copilot would hold the shifter in place for certain rough climbing and this would work but how do i remedy for the long haul?
Old 04-08-2008, 03:30 PM
i dont know much about transmissions, but you have an older truck simmilar to mine (1980 k-10), and my transfer case linkage is worn out, one time the linkage got stuck between neutral and 2wd high. cuase a lot of problems.
i would start with the linkage.
good luck
Old 04-08-2008, 07:59 PM
Might be worn internally too.
Shane
Converting an '83 Scottsdale 2Wheel Drive to 4x4 ChevyJim Suspension - Brakes - Steering 9 03-25-2007 07:55 PM
83' s-10 700r4 4x4 trans took a dump proflow Transmission - Rearend 2 12-12-2006 12:51 AM
which oil pump for a 406? high volume or high pressure? 406 ss monte Engine 23 09-10-2006 07:48 PM
Jamie's 83' chevy 4x4 jamie dengler Introduce Yourself 1 04-08-2006 10:46 AM
headers for a 83 chevy 4x4 with sbc brodix angle plug heads jrtraveler79 Engine 1 04-23-2004 11:04 PM
