83 monte carlo rear end questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-23-2011, 05:52 PM
i cant figure out what rear is in my car, its and 1983 monte carlo (LS) can someone please help me!!! its a limited slip thats all i know
Old 01-23-2011, 06:11 PM
ericnova72's Avatar
More for Less Racer
What exactly are you looking to find out about it?? Your question is not very specific.
Old 01-23-2011, 06:50 PM
what size rear?, and any ideas of what gears could be in it
Old 01-23-2011, 06:59 PM
RippinRon's Avatar
7.5" 10-bolt. Check the glove box or under the trunk lid for the option code list. Rear end ratios start with G.
G72-2.14 ratio
GH2-2.29 ratio
GU1-2.41 ratio
GM8-2.56 ratio
GU2-2.73 ratio
GU4-3.08 ratio
GU5-3.23 ratio
GT4-3.73 ratio
G80-limited slip differential
Old 01-23-2011, 07:21 PM
big gear head's Avatar
High Performance Rear Ends
All of the '79 to '88 G body cars had the 7.5 10 bolt with 26 spline axles, except the Buick T Type, GN and some of the Olds 442s. The only limited slip differentials that were offered in these G body 7.5 rear ends were the Auburn and Governor Lock. There are much better after market differentials available for them now.
Old 01-27-2011, 02:29 PM
thanks i'll look
1983 monte carlo rear end questions cutthroatkid Transmission - Rearend 25 08-03-2010 11:51 PM
86 Monte Carlo questions remist17 Hotrodding Basics 6 04-25-2010 08:18 AM
Rear end for 1986 Monte Carlo SS McSS86 Transmission - Rearend 7 02-01-2010 01:55 AM
MOnte carlo 79 rear end? rockabilly66 Transmission - Rearend 8 11-22-2007 10:08 AM
monte carlo v6 rear end ? 85irocss Transmission - Rearend 1 08-22-2002 03:11 AM
