83 S10 2.8L w/700R4 4WD to 94 4.3L 4L60 2WD conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-06-2009, 10:32 PM
Ok. I have a 1983 Chevy S10 Blazer 4WD I am trying to get back into good running shape as a daily driver. Nothing special, just something I can rely on.
It currently has a 2.8L 178 CID V6 engine with a TH700R4 transmission and then whatever model T-Case is in there (im not sure to be honest).
The truck had been sitting for 4 years because the transmission constantly leaked fluid and wouldn't have any pull to it in any gear and had previously lost the reverse gear...I have no idea what happened. I have thought about rebuilding the transmission which I can get done for $600 with me taking it out and reinstalling it. Or I could go buy a used one from craigslist.com or a junkyard and pay $200, 300, 400, 500 etc for one and have absolutely no guarantee on it and not know truly what condition it is in.
Keep in mind that there are other parts I need to replace on my Blazer such as most of the interior due to a missing drivers window and the like.
A friend of mine has a wrecked 1994 S10 Blazer but it has a good 4.3L Vortec engine with a 4L60 transmission but it is 2WD. I can buy the truck for $600 and I know the engine and transmission are good. It is also newer and more reliable.
Now my question is, Can I do an engine and transmission swap and put the 1994 drivetrain in my 1983 and still have 4WD using the 2WD transmission but bolting the T-Case to it.
I have read that I could possibly change out the output shaft and tailhousing on the 2WD one with the old 4WD one and bolt the T-Case to it and not have to change the driveshafts or anything.
I really need some advice on what problems I could encounter with this, that is if this will actually work. And if you could possibly post instructions/pictures of maybe a "How To" on this, that would be great. Especially since I am only 17 y/o and have never done any of this before.
Sorry for typing so much but I wanted to be as clear/concise as possible so everyone could understand my situation.
Thank you,
Danny
Old 01-22-2009, 03:17 PM
v8 dan's Avatar
Dan 84 s10 with 5.7 TPI,700r4
s10 swap
I just got done putting a 5.7 TPI in my 84 s10, it was fairly easy, I do know that everything from the 4.3 will work but you have to pretty much use it all unless your 2.8 was fuel injected, as for as the tranny I am not sure unless you just made it a two wheel drive,just leave out the transfer case out and the front drive shaft, buest place to get info on this is www.v8s10.org thats where I got all my info just becareful they will try to talk you into putting a smallblock in it.
Old 01-22-2009, 06:29 PM
You will a oil pan from a 4WD 4.3 . Also the exhaust crossover pipe from
a 4WD . Use the transmission and driveshaft from the 4.3 as is, it should
fit for a 2WD application with out the front driveshaft .
Old 01-22-2009, 10:00 PM
aight. i appreciate it. i'll check on all that.
Old 01-25-2009, 09:28 AM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
GM has a 3.4L crate engine that would be a direct replacement for the 2.8. Or find a 3.4 out of a rwd application (Camaro) works as well. One guy on a Jeep Cherokee forum I go to has a 3.8 out of a Camaro swapped into an old 2.8v6 Cherokee engine bay.
Old 01-27-2009, 10:07 PM
ok. cool. i'll have to check that one out. i'm kinda wanting a little more power in the s-10 but i might have an application for a 3.4L later on... i always have some project im workin on. lol.
thanks.
4L65-e conversion from 4wd to 2wd. 48pickup Transmission - Rearend 2 08-30-2007 02:45 AM
4wd to 2wd conversion burninrubbah617 Transmission - Rearend 4 01-20-2006 03:06 PM
