83 Z28 Transmission - YIKES! - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-25-2003, 05:49 AM
Red face 83 Z28 Transmission - YIKES!
Stumbled in surfing the web hoping to find an inexpensive resolution to problems I'm having with the transmission in my 83 Camaro Z28, I hope you all can help. Here's the deal...
I've got an automatic transmission with overdrive (1,2,3 and drive). The first gear to go was drive, then shortly after I lost 2nd and 3rd. All I've got now is 1st and Reverse. When I put the car in drive it doesn't shift out. So I end up rapping out in first gear and let off when I get close to red-lining it. When my speed decreases enough for the transmission to kick back in, I do it all over again. I was told to check for a compression/hose leak but found nothing. A few months prior of the transmission going out the transmission linkage cable came undone and instead of buying the correct bolt to reconnect it, I afro-engineered it so that I could atleast shift gears without having to get under the car and shift manually. I don't think that has anything to do with it, but I thought I'd throw it in. Transmission fluid has always been up to snuff. Any ideas?
Old 11-25-2003, 07:20 AM
willys36@aol.com's Avatar
Wiki Edits: 21
It sounds like this car is your daily driver. Why in the world don't you take it to a tranny shop and get it running again?
Old 11-25-2003, 07:31 AM
I must have given you a false impression by saying the gears went out 1 by 1, but no...it's not my daily driver. That's what my 93 Ranger is for.
A while back, my camaro was parked next to a ford ranger that had started on fire due to a short in the alternator and caused damage to the front quarter panel and tire. My insurance policy didn't cover the accident and I haven't gotten to the repairs yet so I'm storing the camaro 30 miles away. Any ideas???
Old 11-25-2003, 07:38 AM
Wiki Edits: 21
Repaint the quarter panel and get a new tire.
Old 11-25-2003, 07:43 AM
lol
I replaced the tire right away, but haven't painted the quarter panel. Just going to repaint the car.
Name:	chris\'s camaro.jpg
