-   -   830 cfm holley (http://www.hotrodders.com/forum/830-cfm-holley-226810.html)
80ta 12-04-2012 04:42 PM
830 cfm holley
Have an old 830 double pumper that I thought I might rework and put on my 468.
468
pocket ported 820 heads, 2.19 / 1.88
lunati 60213 hydraulic roller 241/249 @50 .625/.625
airgap
cr 9.95
Holley
has had choke tower taken off ( I think ) so no number on top
only body numbers are on the side P32 R5
Base 48354
butterfly 172, 7/64 hole in front blades
metering plates 9108
squirters 31
power valves both blocked
pumps are 50 front and back
this is how I got it, is it worth while trying to set it up for my engine, was told to put a 1/34 base on it to increase flow and so the secondaries come in slower as these open really fast
thanks
vinniekq2 12-04-2012 07:34 PM
no power valves on the street might be hard to tune.
when the car is running,dyno the beast and tune it there. 830 is a decent size for a street car.consider using an open plenum intake for more flow
