830 cfm holley - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-04-2012, 03:42 PM
830 cfm holley
Have an old 830 double pumper that I thought I might rework and put on my 468.
468
pocket ported 820 heads, 2.19 / 1.88
lunati 60213 hydraulic roller 241/249 @50 .625/.625
airgap
cr 9.95
Holley
has had choke tower taken off ( I think ) so no number on top
only body numbers are on the side P32 R5
Base 48354
butterfly 172, 7/64 hole in front blades
metering plates 9108
squirters 31
power valves both blocked
pumps are 50 front and back
this is how I got it, is it worth while trying to set it up for my engine, was told to put a 1/34 base on it to increase flow and so the secondaries come in slower as these open really fast
thanks
Old 12-04-2012, 06:34 PM
vinniekq2's Avatar
no power valves on the street might be hard to tune.
when the car is running,dyno the beast and tune it there. 830 is a decent size for a street car.consider using an open plenum intake for more flow
looking for vacuum port on 830 holley 406 bug Engine 2 06-01-2008 05:39 PM
holley 2300, what cfm??? garyCCR Engine 11 03-24-2008 08:28 PM
Holley Carb Cfm? Checy_Guy Engine 5 07-12-2005 08:22 PM
Holley 830 annular discharge lluciano77 Engine 2 06-26-2004 12:48 PM
600 cfm holley vs 750 cfm holley 85 regal Engine 7 11-27-2002 06:25 PM
