84 350 overheating - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-23-2011, 06:46 PM
84 350 overheating
have a 84 vet 350, crossfire removed, stock gm manifold elbrock 600 carb, new water-pump, new thermostat, water seems to push right thru the radiator but 15 Min's at idle 225 degrees. motor runs great but over-heats :-)
Old 12-23-2011, 07:59 PM
overheating..
A little more information would be helpful.. what vehicle is the motor in now? Do you have any type fan shroud in place or duct work to funnel the airflow where ir is needed? Are you using a 6 bladed fan that will flatten out and not actually move air? Are you using a thermostat and if so what temp stat is it?..
You need to keep the water in the radiator long enough for the air over the fins to have a chance to cool it. you can run a smaller pulley on the crankshaft or a larger one on the pump to slow the flow. If you are not running a exposed motor then build a shroud and seal around the radiator to pull the air through,otherwise the air will not move past the fins.after more info there may be more ideas on cooling.
Old 12-23-2011, 08:05 PM
Toms,
I believe the Vet had a serpentine belt with a reverse flow water pump. If a conventional water pump is installed the water will not flow correctly and the engine will overheat.
Scholman
Old 12-23-2011, 09:03 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
welcome
lots of good people and info
we like pics also
overheating or not??? tnsmith10 Engine 9 10-27-2007 08:41 AM
overheating SBC ferrari stu Engine 12 03-19-2006 05:47 PM
overheating 350. what else can I do? LA5 Engine 14 06-24-2004 09:33 AM
Keep overheating maxharvard Engine 14 06-23-2004 06:15 AM
305 overheating brad11957 Engine 35 05-28-2004 01:41 AM
