84 700R4.... No computer
anyone using a mid 80's (84) 700R4 without the computer. Looking for how to control the lockup. I know how to release the lockup thru brake light switch and low vacuum switch but not how to tell the trans WHEN to lockup.
Not looking for a link to the 80-125 dollar kits, looking to do it myself. I saw the wiring diagram in the stickies but I don't think that will work will it? that one is assuming you have the ecm/pcm right? Thanks |
At the Bonneville Salt Flats, first gear is known as 130 mph. |
700r4
so that wiring circuit will work....
pin A? No computer whatso ever... Cool |
there were 700r4 trans in 1984 and earlier
700
Drive train is from a 84 z 28
305/700R4 |
the 1984 trans will have many switches and wires on the valve body.
the 12 volt power to pin "A" and a ground wire to "D" may not provide lock up of the converter clutch
no puter
your comment was : Quote:
You need 12 volts to the lock up solenoid and a method to provide a ground if the solenoid is a 2 wire solenoid. Your old trans 1984, may have a 1 wire solenoid. There may be a proper pressure switch currently on your valve body. You need a "N-O" switch. N-O mean normally open. Pressure switch in the proper v-body hole for lock up in over-drive and you are good to go. I would suggest trying the 12 volt wire in to the "A" pin hole and ground wire in to the "D" pin hole. The transmission may lock up the converter in 4th gear only or it may lock the converter up in 2 , 3 and 4th gears as the early 700r4 was setup like that
| 700r4 do i need the computer for it to run??? | HANK B | Engine | 16 | 05-18-2011 11:53 AM |
| Swapping my engine from computer to No computer,whats the best way?? | Schoust | Engine | 3 | 03-26-2010 02:31 PM |
| How do u wire a 700r4 with a computer | saskroughriders | Transmission - Rearend | 15 | 08-13-2009 05:30 PM |
| 4.3 Distributor computer to non computer | grumpy1 | Electrical | 6 | 04-19-2007 05:37 PM |
| 700R4 with Vortec Computer Controlled Engine | capps | Transmission - Rearend | 2 | 07-30-2005 02:17 PM |
