84 Camaro horn - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2008, 04:24 AM
Last journal entry: 69 Mustang
84 Camaro horn
I need some help trying to wire up a electric horn. There is one wire ran. I believe it's running from the horn button on the steering wheel. I have a four point relay, but now I'm told that I should have bought a five point relay. How can I find out where that one wire(green) is running from and what is the correct wiring for this relay? For example, is the power coming from the fuse box or directly from the battery? I'm trying to avoid placing a remote button inside the car. I've tried looking at other diagrams posted but no luck.
Old 08-09-2008, 06:20 PM
are you replacing a dead horn, horn button doesn't work, or trying to completely re-wire it? I just replaced my 1 wire horn with a generic auto parts store horn and had to add a second wire (ground).. stock horns ground through their bracket not a wire.. i think.
hope that helps
Old 08-10-2008, 11:19 AM
T-bucket23's Avatar
Wiki Edits: 26
Post the pin numbers fron the relay you are using or the model number and we can help. There are only a couple different numbering schemes but I dont want to give you bad info. The relay model number would also help.
Chet
The Camaro Guy ZedLepplin Introduce Yourself 1 03-08-2007 06:55 AM
Need some help on a 84 Camaro Z28 LXZ590 Engine 5 12-10-2006 02:39 PM
84 Camaro SB 84 Z28 Hotrodding Basics 16 02-07-2004 12:27 PM
454 in an 84 camaro HORTON Engine 10 10-09-2002 11:35 PM
'84 Camaro emblems nomadic_cam Body - Exterior 3 09-25-2002 10:17 PM
