indicator marks on the gears
Are you using timing gears instead of a timing chain? If you were to look at the distributor rotar, with the cap off, as a clock face then the rotar should be pointing at the 5 o'clock position, that should put the #1 sparkplug wire right there also. Hope I didn't confuse you.
http://www.chevytalk.com/ Contacts here might also help you, I use it for reference materials. Todd RAt Rods Rule! |
I am using a timing chain(that badly needs to be replaced). i haven't had time to check out what you said. but i will tomorrow it is still dark right now and I won't have any time later today. I sure hope it works. thanks for your help!
Are you talking about the mark on the vibration dampener and the tab mounted on the timing cover? Did you remove the distributor for some reason? Were you told the car would run or does it need timing chain replacement? The timing chain can only wear so much and then the engine will not stay in time or will not be timed at all. How many miles are on this engine? Was this engine ever rebuilt? You will need to bump the starter, with the plugs removed preferably because its easier to bump the engine and not have it JUMP or try and start. Bring the dampener mark to the spot on the tab where the engine is in time then look at the distributor rotsr with the cap off, you will need to trace the #1 wire to the cap first and mark the cap there.. I don't know what timeing is for an 84 Camaro, you will have to look that up. or try these people; http://www.chevytalk.com/
Todd Rat Rods Rule! |
That is a lot of questions...I will see how many I Can Answer.
1. My original question was with the crank gear and cam gear lined up with each other by the indicator dots. Not the vibration dampener and the timing cover tab. 2. The guy I bought the car from put on a new intake and carb,(Edelbrock Intake and a Holly 650CFM carb). He says he messed with the distributor when he changed the spark plugs. 3. The fellow said it would run it the timing was set. I already changed the timing chain and gears because it was only like $25 dollars for the kit and a harmonic balancer puller. 4. The engine has approximately 180,000 miles. As far as i know the motor has never been rebuilt. On another note... I had somebody tell me the carb might be too big for the motor, so i took the spark plugs out so the motor wouldn't have any compression. the motor turned over very nicely. I reinstalled the plugs and got the timing straight. I tried starting it and it turned over OK. I gave it a little gas and the motor didn't wan't to turn over so well. Thanks for your willingness to help out a beginner Todd. I am going to try http://www.chevytalk.com/ right now. |
Weak Starter?
The engine is turning over realy slow. I have had the starter tested at Advanced auto parts. They said it was ok. I have redone the timing, and the plug wires and everything is right now. The battery is brand new. could it be the starter?
If by a drawn out stressed crank you mean that it isn't continous it is a drawn out stressed crank. The battery has 585 Cold Cranking Amps. I have had the battery in a new mercury tracer and it starts just fine. someone @ Chevytalk.com told me to pull the valve covers and make sure the valves are moving...guess i'll do that tomorrow.
Hmm.. Been readin through this post and figured I'd put my 2 cents in... When I had my timing 180 out it didn't cause it to crank slow.. It would crank just fine but have a really odd back fire sound... My suggestion is that maybe its a little to far advanced and the engine is kicking back on the starter. Rotate the distributor clockwise to retard it and see if it will crank then... If so then put a timing light on afterwards and set the timing properly that way. Over tightened valves seem pretty legit too but I've never had this problem so wouldn't be able to tell what it is like..
Bad Starter!
The Starter was bad! I took it to my local Napa store and had the starter tested. The First time it tested positive but it was sparking a little at the connections. The next time it didn't spark and it tested Bad. (ODD) So we tested it again, and again it came out bad. I have another starter ordered and it will get here tomorrow. I will let yall know how it goes!
