84 Corvette Repair? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-22-2006, 06:05 AM
84 Corvette Repair?
I Know The 84 Corvettes Are Some Type Of Plastic Fiberglass?? Composite, I Have Two Cracks In The Quarter Panel , The Rep Says The Norton Two Part Epoxy Or Speedgrip Urethane Will Repair Them, I Have Also Talked To The Norton Rep He Says The Same, Does Anyone Have Any Experience In Working On One Of These Cars, I Am Not New To This, But I Am Very Unfamiliar With Corvettes, Thanks For Any Help, Mike.
Old 03-22-2006, 07:15 AM
roger1's Avatar
It's Sheet Molded Compound (SMC). Check this out:
http://www.abrn.com/abrn/article/art...l.jsp?id=77631
Old 03-22-2006, 07:38 AM
crashtech's Avatar
Technician
Last wiki edit: Epoxy primer
Wiki Edits: 17
If you want to repair SMC in the conventional manner, with mat and resin, there are resins made specifically for this, such as Evercoat's "SMC Fiberglass Resin", #865. Normal fiberglass resin will not adhere well, and should not be used.
Old 03-22-2006, 07:40 AM
roger1's Avatar
I saw your post on this car from last October.
1984 Corvette!! Help Anyone!!
Did you do Barry's test and find out if the surfaces of that car are contaminated?
Old 03-22-2006, 02:00 PM
Yes And Someone Had Just Sprayed Lacquer Primer In Certain Areas, Thanks For Replies, Mike
Old 03-22-2006, 02:33 PM
The Norton will work just fine.
Carry out your V-Groove as wide and gradual as possible.
Installing a Corvette IRS in a 34 Coupe Mc D's 34 Coupe Suspension - Brakes - Steering 12 05-18-2010 12:20 PM
Aluminum stud guns and repair? sevt_chevelle Body - Exterior 5 02-14-2005 04:47 PM
84 Corvette Overdrive Transmission team2nutz Transmission - Rearend 2 12-25-2004 05:47 PM
350 SBC for 84 Corvette azc4vette Engine 3 09-21-2004 02:13 PM
IMPORTANT Car Legislation fsjimmy Hotrodders' Lounge 5 12-03-2003 03:55 PM
